Anti Roll Bar bushes
transit80
Viesti Kirjoittaja transit80 »
Does anyone know where I can get some polybush type anti roll bar bushes for a 96V4???
Tietääkö kukaan mistä voin saada joitakin polybush tyyppi anti kallistuksenvakaaja pensaita, 96V4??
Chris
England
mikali
Re: Anti Roll Bar bushes
Viesti Kirjoittaja mikali »
Haluaakohan hän siis kallistuksenvakaajan puslia vai tukivarren puslia ?
eipä niitä saanut 89 luvullakaan olisko jollakin uus tuotantoa? siksi ne lensikin helveddiin ennen leimaa kun hylky olisi tullut muuten 8)
transit80
Etsin POLYBUSHES etu-anti kallistuksenvakaaja ja 1975 96V4
Im using Google Translate to do this ,I hope it is right :D
Chris
England
kabu
Viesti Kirjoittaja kabu »
Well, google translator doesn't always produce understandable language, especially on words that have multiple meanings on either language :-)
The guys are wondering whether you are looking for the D-shaped anti-roll bar rubber bushes or the bushes for upper or lower wishbones? Are you looking for original type bushes or harder polyurethane ones?
I have a 1962 two-stroker and that does have an anti-roll bar that is supported to the chassis by two D-shaped rubber blocks that have a hole through them. If I remember correctly the laver V4's (at least 1974 and 1975 that I used to have) did not have any anti-roll bar as standard.
The upper and lower wishbone bushes are available (probably even in PU for rally use) but I am not aware of anyone producing the anti-roll bar bushes, of course they may still exist.
For instance Veteranshop.se has the wishbone bushes (The prices are in SEK):
- Upper wishbone ( http://shop.textalk.se/se/article.php?i ... grp=195527 )
- lower wishbone ( http://shop.textalk.se/se/article.php?i ... grp=195527 )
Tahtari-Pekka
95, 1962 (MA) - 900 OG, 1984 (MA)
kabu
Since the Saab anti-roll bar bush and its mounting is fairly simple I think I would look whether similar bush has been used on some other car as well.
A simple search shows for instance that Ford Escort rear anti roll bar bushes look really similar to the ones that I have on my stroker. If the bush hole dimension is correct but the mounting dimensions are a bit different, one can quite easily fabricate the required mounting clamp for the dimensions suitable for the new bush.
http://www.polybush.co.uk/shop/view/265 ... cort_(MK1)
Tahtari-Pekka
transit80
`Kabu`, thanks for the reply,I can confuse most English people :lol: . The bushes I am looking for are the D shaped ones and the ones for the end of the ARB, I have replaced all of the suspension bushes with Polyurethane ones and this is what I would like for the ARB. I have looked at other model applications and the Escort is near to it, the D shaped one has a hole of 13mm and is 45mm high and the end one would have the same size hole and be approximately 30mm long.
Chris
