Hi,
I spent my whole morning under the car. I still could not remove the lower dash fascia, even though I removed all the visible screws. (even the one behind the ashtray) Something holds it back in the middle.
Anyway, I managed to mount the new overpressure switch + pressure transducer.
Does the pressure switch have only two connector connected? I can see three pads on the unit, but one of them was not connected in my car.
It was a pain to get the knock sensor into position. The trick was to hold the screw with a thin wire from above.
... And hopefully this is the last issue I have...
I could not connect the R pipe of the solenoid switch. As I understood it should go somewhere on the pipe from the airbox (AMM) to turbo. The pipe I have in my car does not have a connector for it. Do I need to get a different pipe or I just missed it?
When the engine is running and I increase the RPM to say 3000, I can see that there is some pressure building up from the solenoid's R terminal. Does it mean that the system is working (besides the open R pipe?) When I turn the key on (engine not running) I can barely hear a ticking noise from the solenoid when I put my ears on it
. If I remove the connectors from the pressure transducer then there is a laud clicking noise from the solenoid valve.
Can I drive the car with open R pipe without any damage to engine?
Thanks for clarifying that I purchased the wrong ECU unit.
Does anyone need it?
Regards,
