hello - saab fan!!! i need help - water pomp saab 99/ 1976
ska_69
Viesti Kirjoittaja ska_69 »
I welcome! Fans of saabs!!!
My name is Konstantin, I from Russia, the city of Moscow.
Has bought last year to itself a saab 99 combi coupe. The brown.
Like all anything, only it is necessary to change a water pomp. On open spaces of our country I have not found a water pomp. ((((((
I address to you - Finns - can at you where that can be found a water pomp on a saab 99????
Here the data of my car:
vin - is absent
Year of manufacture - 1976
The engine - B120P02001657
Body - 99766003476
Capacity - 100 horsepowers
Forgive for language - used the translator.
With the best regards!!!
The item with. Come on my site - http://www.saab-club.su - club of fans a saab in Russia.
saab 99 combi coupe, brown, carb, 2,0......under construction
lucaf
"kukkahattu"
Re: hello - saab fan!!! i need help - water pomp saab 99/ 1976
Viesti Kirjoittaja lucaf »
Nice 99 you have got! :)
Finding a new waterpump in an old saab 99 is a challenge also in Finland. I think it is easier to find such part from Sweden? The replacement operation is another a challenge since the cogwheel where the pump is connected gets broken if the pump is removed incorrectly.
What about this: http://www.geocities.com/saab99ewp/
ska_69
Thanks for the answer)))
The gear pinion gear is perfectly in order)))
The previous owner assorting the motor has broken blade a pomp, and the epiploon wept for a long time already....
There is a variant to put consolidation to the place of a shaft, and to establish an external pomp....
But very much it would be would be desirable that all in the original.
Just it also is described on the site offered by you.
