I have a '94 NG 900 (non-turbo) which is having problems with reverse gear popping out and grinding. I've tried the usual things like replacing the clutch cable and adjusting the gear linkage but it still pops and grinds.
The engine mounts and clutch seem to be worn out, and I thought they could have something to do with it, so I'd like to have them replaced. I wondered if anybody could recommend where I could have this done in Oulu, and give an idea of how much it might cost (I have a feeling that Aine might be quite expensive.)
I know that the NG 900 is famous for having reverse problems, so if I have the gearbox taken out to replace the clutch, I thought I could have the reverse gear parts replaced at the same time, but would this be expensive?
Many thanks,
Mark.
