Englanniksi tiivistettynä:
VE (Volumetric Efficiency)
The engines ability to fill the avalible volume in the cylinders.
VE Table
The ratio (or percentage) of what volume of fuel and air actually enters the cylinder during induction to the actual capacity of the cylinder under static conditions. Engines that can create manifold pressures above atmospheric will have efficiencies greater than 100%.
