Installation of an aftermarket player.
positiv
Viesti Kirjoittaja positiv »
Hi!
I have an 9-5 estate My00. And I find out that the aftermarket player drain my battery. So Am now going to order me an adapter. Where I also can use the buttens on the stearing wheel.
So can you help me out with where I can order that adapter. This is an 2 din android 4.4 player from Kina.
About the drain of the battery. Without the player and amplifier connected I have 10 milliamp on my multimeter. And when I connect the amplifier who is for the sub. It going up to 30 milliamp. What is normal for an 1000w rms amfibier to drain. Is 20 milliamp ok? And how much shudd the player drain the battery when is monted up? My limit is 50 milliamp.
Bent
positiv
Re: Installation of an aftermarket player.
Then I have fix the power consumption. And the player now draws 10ma. Have also replaced the amplifier. So now I have a total power consumption of 27ma. Has also got the steering wheel control to and function. Then I'll will finish installing the audio player today.
