2,8 V6 Turbon tiedot
Saabin konseptit ja tulevaisuuden suuntaukset.
Toby
Viesti Kirjoittaja Toby »
Tehdään oma aihe tästä uudesta V6:sta.
Alla Saabcarsonlinestä kopioimani tietopaketti, josta mm. selviää, että kone kasataan Holdenilla kengurumaassa!
14 February 2004. The new 2.8L V6 Turbo engine (specifications)
Text by Saab Automobile
DETROIT – General Motors expands the family of advanced global V-6 engines with the sophisticated 2.8L V-6 Turbo – a transverse-mounted compact and lightweight powerhouse that delivers the performance of a larger-displacement engine.
The 2.8L V-6 Turbo debuts in the all-new Saab 9-3 SportCombi, Sedan and Convertible, continuing the brand’s heritage of turbo power established in 1977. It is the most sophisticated turbocharged engine ever offered in a Saab vehicle, delivering excellent responsiveness through low-speed torque and high-rpm power as well as exceptional refinement.
Technology such as a dual-scroll turbocharger and variable intake valve timing helps the 2.8L V-6 Turbo achieve 250 horsepower (184 kw) and 258 lb.-ft. of torque (350 Nm) in the 9-3.
“The 2.8L V-6 Turbo has a strong, linear feel that gives the impression of a larger-displacement engine,” said Tim Cyrus, global V-6 chief engineer. “The feeling of power is tremendous, but so is the smoothness and refinement built into the engine.”
Developed in conjunction with other engines in the global V-6 family, turbocharging was designed into the architecture’s structural parameters. The powertrain engineers’ experience with turbocharging at Saab was integral in refining the engines’ performance, with the 2.8L V-6 Turbo delivering maximum torque by 2,000 rpm and maintaining it through 4,500 rpm. Ninety percent of peak torque is available from just 1,500 rpm. This broad performance spectrum results in an engine that effectively offers two torque curves: a linear curve that delivers exceptional low- and mid-range torque, and higher-rpm power that benefits from the pressure of the turbocharger.
“It’s almost like having two engines on tap,” said Cyrus. “At low speeds, the inherent torque of the V-6 pulls strongly, but it has the power of a larger-displacement engine when the full power of the turbo system is called up.”
Inside the engine
All engines in the global V-6 family share traits that include a lightweight aluminum cylinder block with iron cylinder sleeves, an aluminum structural oil pan and aluminum cylinder heads with four valves per cylinder. The 2.8L V-6 Turbo builds on those strengths with components and technology developed specifically for the turbo system, including:
Twin-scroll turbocharger delivering approximately 9 pounds of boost (0.6 bar)
Integrated charge cooling
Unique cylinder heads made from 356T-6 aluminum and featuring sodium-filled exhaust valves
Forged steel crankshaft and sinter-forged connecting rods strengthened for turbocharged loads
Pistons with anodized ringlands designed for turbocharger boost pressure
9.5:1 compression ratio
Piston oil cooling jets
Unique camshaft profiles designed for turbocharger performance
Hydroformed “dual skin” exhaust manifolds with stainless steel inner liners
Engine-mounted oil cooler
The turbo system features a unique, twin-scroll turbocharger. It has an integral bypass valve and is fed by two exhaust ducts – one from each cylinder bank. Separating the exhaust gas pulses with two compressor zones improves gas flow and reduces energy loss. The turbo system’s charge cooler promotes performance by reducing the temperature of inlet air.
Additionally, the 2.8L V-6 Turbo employs a conventional, single-stage intake manifold and variable valve timing on the intake camshaft – the variable valve timing helps optimize performance and emissions control. Also, a variable fuel pressure system helps ensure smooth idle and driving characteristics. Valve timing and fuel pressure are managed by the engine’s powerful controller, a 32-bit micro-hybrid system which is calibrated specifically for the turbocharged application.
The sophisticated controller operates under a torque-based engine management strategy designed to deliver smooth performance in all driving conditions. The system works with the vehicle’s transmission to modulate torque, providing stirring performance and excellent engine response. The system also can limit torque in low-traction conditions, helping provide confident, sure-footed driving.
Cross-globe connection
The 2.8L V-6 turbo is the third variant of the new global V-6 family – a technologically advanced 60-degree, dual overhead-cam architecture designed to produce strong power and excellent fuel economy to meet different needs in markets around the world. Engineers from GM Powertrain in North America and FGP – the Europe-based Fiat-General Motors Powertrain consortium – as well as Holden collaborated on the development.
The global V-6 engine family also includes a 2.8L V-6 VVT normally aspirated version which debuted in the 2005 Cadillac CTS, as well as a 3.6L V-6 VVT version that also is available in the CTS. The 3.6L V-6 VVT also is available in the 2005 Cadillac STS and SRX, as well as the Buick Rendezvous and LaCrosse. It is available under the Alloytec brand name in the 2005 HoldenCommodore, Calais, Berlina short-wheelbase, Statesman and Caprice long-wheelbase, Ute, Cab Chassis and Crewman.. Both VVT engines use variable valve timing on the intake and exhaust valves for optimal performance and emissions control.
The 2.8L V-6 Turbo is built at Holden’s Port Melbourne, Australia facility, along with 3.6L variants of the global V-6.
2.8L V-6 Turbo Specification
Assembly site: Port Melbourne, Australia
Applications: Saab 9-3 SportCombi, Sedan and Convertible
Type: 2.8L DOHC turbocharged V-6
Displacement (cu in/ cc): 170 / 2792
Bore x stroke (in x mm): 3.50 x 2.94 / 89 x 74.8
Block material: aluminum
Cylinder head material: 356T-6 aluminum
Intake manifold: cast aluminum
Exhaust manifolds: hydroformed “dual skin” w/ stainless steel liners
Compression ratio: 9.5:1
Valve configuration: overhead cam; four valves per cylinder
Valve lifters: hydraulic lash adjuster, roller finger follower
Firing order: 1 - 2 - 3 - 4 - 5 – 6
Fuel system: sequential fuel injection
Horsepower (hp / kw): 250 / 184 @ 5500 rpm (est)
Torque (lb-ft / Nm): 258 / 350 @ 2000 rpm (est)
Fuel shut off: 6500 rpm
Crankshaft: forged steel
Connecting rods: sinter-forged metal
Additional features: electronic throttle control, variable intake valve timing, variable fuel pressure, pressure-actuated piston cooling jets, extended-life spark plugs, extended-life coolant, GM Oil Life System, oil level sensor, extended-life accessory drive belt
Source: Saab
Saabisti #2397
9-5 2,0t Linear Wagon vm.2002
Seat Alhambra 2,0TDI 4WD vm. 2013 (11/2012), mutta silti:
"Saab is The Truth, The Whole Truth and nothing but The Truth."
TuuSaR
Viesti Kirjoittaja TuuSaR »
2,3T sport
Viesti Kirjoittaja 2,3T sport »
Noitten koneeseen lätkittyjen logojen lisäksi voisivat laittaa Saabmaisen öljytikun :roll:
MtSound
Viesti Kirjoittaja MtSound »
Enpä asiasta mitään tiedä, mutta jotenkin ikävä yksityiskohta tuo saab-merkin ja V6 turbo-tekstin irtoläpyskä tuossa koneen päällä. Tuntuu, että siihen voi liimata merkin kuin merkin. Olisi vain panostettu sen verran, että olisivat tehneet merkinnät suoraan koneen kanteen. Sitä laatuvaikutelmaa.
jussi
Saab 9³X -10 #2508
OG 900 Cab -87
teesalama
Onko tämä nyt semmoinen "bulk"-moottori.
Saa varustaa haluamallaan merkillä tilauksen mukaan.
Taitaa tosiaan olla pitkästä aikaa moottori, jossa tosiaan ei ole "saabin" öljytikkua.
Noh, väliäkös kai sillä jos vaan toimii..
se93tbo
Viesti Kirjoittaja se93tbo »
Teemu kirjoitti:Onko tämä nyt semmoinen "bulk"-moottori.
Niin tuo samainen öjlytikku löytyy mun automaatista laatikkona AISIN, siis automaattilaatikon öljytikkuna.
9-3.1972
teesalama
se93tbo kirjoitti:
Juu juu, mutta nyt tarkoitin sitä "perinteistä" moottoriöljyn tikkua. Sehän on ollu jo 99:stä aina 9-5:een...
se93tbo
Teemu kirjoitti:
se93tbo kirjoitti:
Tiedän,on mulla ollu 96,99,99 ja sit toi 9-3 missä on jo osia sekoiteltu sitä tarkoita. Tässä uudessa vielä enemmän sekoittelua :wink:
9-3.1972
Turbo Sensonic
Teemu kirjoitti:Taitaa tosiaan olla pitkästä aikaa moottori, jossa tosiaan ei ole "saabin" öljytikkua.
Sport Sedan 1.8i:ssä on samanlainen öljytikku, mutta moottorihan ei olekaan Saabin tekemä, vaan :evil: pelin peruja.
#1438
NG9-5 2.0TTiD 3/2011
NG9-3CV 1.9TiD 7/2007
Toby
Tänään julkaistun lehdistötiedotepaketin mukaan V6 tulee tarjolle kahdella eri teholukemalla (molemmat siis ahdettuja kuitenkin), ARC ja Vector -varustetasoissa kone tarjoaa 230 hevosvoimaa, kun Aerossa on tuo aiemmin mainittu 250. Eli sama taktiikka kuin 9-5:ssä, missä 2,3T:ssä on vähemmän tehoa kuin Aerossa!
Saabisti #2397
CC Aero
Viesti Kirjoittaja CC Aero »
Toby kirjoitti:Tänään julkaistun lehdistötiedotepaketin mukaan V6 tulee tarjolle kahdella eri teholukemalla (molemmat siis ahdettuja kuitenkin), ARC ja Vector -varustetasoissa kone tarjoaa 230 hevosvoimaa, kun Aerossa on tuo aiemmin mainittu 250. Eli sama taktiikka kuin 9-5:ssä, missä 2,3T:ssä on vähemmän tehoa kuin Aerossa!
Tuohan kuulostaa lupaavalta. Uutta softaa vaan sitten kehiin. :D
potkuhousu
Huomasitteko että uusissa V6 turbo koneissa ei ole enään Trioni8 vaan Bosch Motronic ohjelma.
Jyrki alias potkuhousu
SS-K #1636 STCF #2
CC Aero
potkuhousu kirjoitti:Huomasitteko että uusissa V6 turbo koneissa ei ole enään Trioni8 vaan Bosch Motronic ohjelma.
Pelkkää plussaa virittäjän näkökulmasta, tietämystä pitäisi löytyä kotimaastakin. :wink:
Pieni lisäys vielä. Onkohan se GM:n 3,6 V6 kuinka pitkälti sama kone tuon kanssa? Tietääkseni ovat samaa moottoriperhettä. 3,6 litraa ja turbo kuulostaa aika kivalta yhdistelmältä.
Turbo Sensonic
Toi on vähän ikävämpi juttu ja voi tarkoittaa sitä, että tulevaisuudessa Saabeissa ei enää ole omaa Trionic -moottorinohjausjärjestelmää :roll:
#1438
Turbo Sensonic
TuuSaR kirjoitti:Kuva
Täältä suorituskykyarvot Sport Combin moottoreille:
http://media.gm.com/servlet/GatewayServ ... ocid=12511
#1438
