BioPower
Vuonna 2010 markkinoille tullut täysin uusi 9-5.
veini siekkinen
BioPower
Viesti Kirjoittaja veini siekkinen »
Käykö e85 biopower ohjelma my 2010 maaliin loppuvuotiseen jos ei ole alkuperäinen biopower.
tarviiko muutoksia.
valtteri
Re: BioPower
Viesti Kirjoittaja valtteri »
Nimimerk."suorsa" tietänee sillä hänellä oli ainakin suunnitelmissa muuttaa hänen ent.NG biopoweriksi.
Saab Ng 9-3 t -08
"1159"
suorsa
Re: BioPower
Viesti Kirjoittaja suorsa »
Tuommoista joskus kirjoitin trionictuninkiin. Softien sopivuus vaatinee saman pohjasoftan.
Needed:
- Fuel line 13223825. I bought mine from local Saab dealer.
- Part for home made fuel line. 2pcs connector http://www.finjector.com/verkkokauppa/e ... ew/532282/ and some fuel line.
- Bracket 13310027. I bought mine from local Saab dealer.
- Ethanol sensor 13577394 I bought mine from ebay but seems that seller has left the business..
- Connector for ethanol sensor. I bought mine from finjector.com but the site is down right now so I can't give link.
- wire 3pin. Also from finjector
- connector for ECU connector, the correct one should be molex mx64, but I used a little bit different. The correct also might be found at og9-5 navigation unit.
- connector for underhood fuse block. I don't know correct name - picked up from my tool box :)
- MDI + TIS2WEB to configure ECM
Remove original fuel line over the engine and intake manifold. Install new one (13223825). Install bracket and ethanol sensor. Make new fuel line from ethanol sensor to original fuel line (which will continue under the car).
Connector wires to ethanol sensor connector. Install it to ethanol sensor. Find nice way for wire. I put it together with injector harness. Unconnected end must go to the ECM. Connect pin3 to ECM X1-connector (upper one) pin 38. Connect pin 2 to ground. Connect pin 1 to underhood fuse block X3-connector pin 8.
Connect MDI to car make SPS to ECM. Check ethanol-% is correct (MDI + GDS2 -> ECM -> information). If you want ethanol-% also shown at cluster I think you also need SPS cluster. I didn't done that.
Refuel with RE85 or E85.
veini siekkinen
Re: BioPower
Kiitos tiedosta.voi olla että jää pelkälle pensalle.bsr tai joku muu.?
valtteri
Re: BioPower
veini siekkinen kirjoitti:Kiitos tiedosta.voi olla että jää pelkälle pensalle.bsr tai joku muu.?
Ruotsin foorumeilla ei Bsr:ää ole paljoa kehuttu ja joillakin ollut paljon ongelmia. Hirsch taitaa olla varmin valinta ja vielä kun sen hinta on -50% alennuksessa niin hintakin jää vähän inhimillisemmäksi > 550 €.(http://www.hirsch-performance.ch/Conten ... 2fLeistung)
Tätä on myös kehuttu ja Suomessakin taitaa olla muutamia
http://www.vermonttuning.com/products/s ... 0t-turbo4/
Saab Ng 9-3 t -08
"1159"
Ristom
Re: BioPower
Viesti Kirjoittaja Ristom »
valtteri
Re: BioPower
Ristom kirjoitti:Tuonkin kun aluksi lukee:
http://foorumi.saabclub.fi/viewtopic.php?f=55&t=150378
Lukeminen sivistää aina 8)
Tuossa ketjussa jutellaan Biopower autojen ( E85:sen ) toimivuudesta Hirschin ja muiden softien kanssa. Kysyjän auto ei ole biopower ja ainakin entinen autoni toimi ihan normaalisti 98 okt. bensalla.
Saab Ng 9-3 t -08
"1159"
veini siekkinen
Re: BioPower
bsr tekeleissä se hyvä puoli etta saa ohjelman vaivatomasti ainakin pois.9-3 aerossa ainakin toimi hyvin.monesti syy löytyy tulpista taikka puolista.
tänään pesty kone huone ja lähti käymään ilman koodeja kuin kello niin puolat ainakin ok. :)
valtteri
Re: BioPower
Tässä muutama keskustelu Bsr > NG9-5, kylläkin Ruotsiksi :? google kääntäjällä voi kääntää jos ei ymmärtäminen muutoin luonnistu niin saa ainakin vähän selkoa.
http://forum.saabturboclub.com/showthre ... trim-ng9-5
http://forum.saabturboclub.com/showthre ... g-1-hirsch
Saab Ng 9-3 t -08
"1159"
