FAQ T5 Check Engine Light
jariha
Viesti Kirjoittaja jariha »
#1851 Jari Haverinen :: Saab 9-3 SC TTiD '09 :: instagram.com/autoileva_veijari
KAPU2
Re: FAQ T5 Check Engine Light
Viesti Kirjoittaja KAPU2 »
Kuva ei näköjään toimi, tässä ohje:
Diagnostic trouble codes (DTC) can be read via the 'Check Engine' light after the lamp test (which lasts 3 seconds) when the ignition has been switched on. The reading of flashing codes can be repeated until the DTC memory has been cleared. The DTC memory is cleared by the dealership using the ISAT, but in an emergency can be done by disconnecting the Trionic ECM connector for at least 5 minutes. Note that the ECM will then lose all adapted values.
How to read diagnostic trouble codes:
1. Stop the engine.
2. Switch on the ignition without starting the engine.
3. After approx. 6 seconds, the 'Check Engine' light goes out for an instant before lighting up again for 3 seconds. This 3 second flash is a warning that the actual flashing code is about to start.
4. The flashing code consists of a number of short flashes lasting 0.4 seconds. The 'Check Engine' light goes out for 2 seconds between each new flashing code (if there is more than one fault).
5. After the last flashing code, the 'Check Engine' light goes out for 3 seconds before lighting up again for 3 seconds, after which the flashing codes are repeated. Readout continues in this way as many times as you wish.
Number of flashes Function
2 Manifold absolute pressure sensor => tarkista MAP alipaineletkut
3 Temperature sensor, manifold => tarkista anturin johdot/vaihda anturi
4 Temperature sensor, coolant
5 Throttle position sensor
6 Oxygen sensor => tarkista lambdan johdot/vaihda Bosch lambda
7 Adaptation
8 Purge valve (EVAP valve)
9 ECM, internal fault
Taimi-täti
Viesti Kirjoittaja Taimi-täti »
Syttyi tuo valo,mutta tuo Englannin taito ei riitä tuon tekstin ymmärtämiseen.Saisiko Suomennoksen?Autohan on og93 t vm.03,etanolisoftalla.
vesa67
Viesti Kirjoittaja vesa67 »
Ei päde tuo ohje sinun autoosi. Etsi SIDin riveiltä Fcod jos kerran auto on etanolisoftalla niin melko varmasti opensid on aktivoitu myös.
Ja sitten kerrot tänne mikä fcod oli ..
Taimi-täti
Täytyy sanoa tuolle ukolle,että katsoo huomenna.
Onneksi talossa 2:si kärryä,pakko se on viedä tuo ukon tonnari ja mennä sillä töihin.
Kiitos jo etukäteen minun puolesta.
ana61
Viesti Kirjoittaja ana61 »
En saanut tuota tekstiä tuolta esiin,sid näytössä jotain häikkää myös ei näytä muuta kuin bensan kulutukseen liittyvän infon.Check ok teksti kyllä kävi näytössä.
tturku
Viesti Kirjoittaja tturku »
Check ok teksti kertoo starttauksen yhteydessä että auton polttimot on ok, ei muuta. Sid infon saat päälle painamalla niitä kahta sidin isoa nappia (+ ja -) pohjassa samaan aikaan. Sitten vaan plussalla ja miinuksella etsimään tuota fcod arvoa. Sid info näyttää yli 30 eri parametriä...
Normitilassa sidiltä näät kulutusta, lämpötilaa, tankilla ajettavaa km määrää joka jäljellä (dte), keskinopeus. Ne ei ole sidinfon arvoja vaan sidin perusarvoja.
core2
Viesti Kirjoittaja core2 »
Että saa kaikki nämä näytöt toimimaan SID:issä on OpenSid ohjelmoitava siis avattava toimimaan.
ana61
Tulihan tuonne näyttöön 33 erillaista tekstiä,mutta ei tuota oikeata.Sidissä toinen puoli näytöstä hukassa,eli ei näytä kuin tuon kulutus puolen.
karg
Viesti Kirjoittaja karg »
Vikakoodin lukija kehiin, niin valon syy selvinnee helposti.
ana61
Uskaltaako tuolla ajaa,käy kyllä nätisti ja tehotkin tuntuisi olevan tallella.
karg
Jos se kulkee normaalisti, niin pintakaasulla voinee ajella esim. diagnosointiin.
ana61
Ok,kiitos.
Taimi-täti
No niin,nyt on vikakoodit luettu ja tulos oli tälläinen p1312 ja p1334 mitä nuo sitten tarkoittavat.Isäntä sanoi,että tuo valo ei palanut tänään oli sammunut itsekseen.
lepisto89
Viesti Kirjoittaja lepisto89 »
Viittaa ETSIÄ käyttämällä aika varmasti DI-kasettiin
Saab 900 Turbo -94 RE85 Holset Rip
Saab 9-3 Turbo - 99
Saab 900 S
#5653
