Kiinalainen 9-5 ym.
Saabin konseptit ja tulevaisuuden suuntaukset.
Re: Kiinalainen 9-5 ym.
9-5T kirjoitti:eiköhän lokasuojat ole kuitenkin terästä.
Ei välttämättä, nykypäivänä tehdään yllättäviäkin osia muovista. Varsinkin, kun tekniset muovit ovat parantuneet huomattavasti, ovat energiasäästävämpi valmistustapa ja edelleen kierrätys on muoveissa suhteellisen helppoa.
http://www.jobwerx.com/images/borealis_ ... e_1_hr.jpg
Plastics Technology magazine, September 2007 kirjoitti:TPO Fenders on X5
BMW X5 FenderA technological breakthrough is claimed for the automotive industry with a front fender for the new BMW X5 incorporating enough additional components to warrant the description of “the world’s first fully integrated fender module.”
The front fender itself is molded of Daplen™ EF341AE TPO resin by Borealis. The material was specifically tailored to meet BMW’s exacting specifications for the X5 regarding improved production cost, safety, high quality aesthetics and environmental performance. The resulting TPO fender is the most complex and highly integrated, class A body application to be seen in production to date. Daplen EF341AE is a high-end, 30% mineral filled TPO based on proprietary Borstar technology.
It is the first time that a fender consolidates such parts and functions as headlamp reinforcements and wheel housing, cleaning systems, airbag sensors, and cooling devices. With integrated functions, this step change in innovation provides a 50% lighter-weight alternative to traditional steel components.
The fender can deform up to 80mm on impact, reducing significantly the potential for major injury to a pedestrian in the event of a low-speed collision and allowing conformance to European pedestrian collision regulations.
Daplen was also selected for its dimensional stability, which prevents warpage caused by expansion and contraction. It also creates an optimal design blend with the rest of the steel exterior body of the new BMW X5. It provides the smooth, high quality Class A surface appearance required.
Sonett73
Viesti Kirjoittaja Sonett73 »
Moi, onks kellään tietoa, miten Kiinan Saabeja on myyty?
Ari
Poy
Viesti Kirjoittaja Poy »
Sonett73 kirjoitti:Moi, onks kellään tietoa, miten Kiinan Saabeja on myyty?
Ari
Ei ole näköjään näkynyt netissä, niin ilmeisesti kertoo siitä etteivät ole saaneet valmiiksi.
Tri-Lo
Viesti Kirjoittaja Tri-Lo »
Poy kirjoitti:
Ari
Ei varmaan kovin hyvin kun niittenhän oli tarkoitus tulla tuotantoon muutaman vuoden päästä muistaakseni. :wink:
ella
Viesti Kirjoittaja ella »
Nyt voisi kauppalehti vaikka otsikoida "Saab valuu Kiinalaisille" :D http://www.businessweek.com/news/2010-1 ... soars.html
Eli jälleenmyyjä kiinan markkinoille löytynyt ja sopimus tehty. Itsellä juuri pari päivää sitten mielessä Spykerin osakkeiden osto muutamalla sadalla eurolla, nyt hinta sitten pompsahti, ainakin hetkellisesti.
Tri-Lo
ella kirjoitti:Nyt voisi kauppalehti vaikka otsikoida "Saab valuu Kiinalaisille" :D http://www.businessweek.com/news/2010-1 ... soars.html
Katoppa joo, ihmettelinkin mistä se tämän iltapäivän pompsahdus tuli.. :)
wla
Viesti Kirjoittaja wla »
Kiinalaiset saaneet 9-5:n ulos.
http://www.wautom.com/2012/12/baic-shen ... orsepower/
Tässä sitä vasta hämärää uutista,Mäkinen rakentamaan WRC autoa Shenbaosta..
http://www.leblogauto.com/2013/01/chine ... n-wrc.html
Aina joku Saabbi...
Komppaaja
Viesti Kirjoittaja Komppaaja »
wla kirjoitti:Kiinalaiset saaneet 9-5:n ulos.
Ei ollenkaan pöllömmän näköinen. Toki mitä se sisältä on, sitähän ei tiiä kukkaan.... :)
SS
Viesti Kirjoittaja SS »
Todella tylsä muotoilu niin ulkoa kuin sisältä, samaa sarjaa muiden kaukoidän ihmeiden kanssa.
Oli: OG9-3 2.0t 2003
Muuta: Kiina TECH2
torque
Viesti Kirjoittaja torque »
sivulinja kuin jokin audi-seat exeo mukaelma. Keula suoraan Koreasta.
Darth Vader reborn...
9-5 2.0t A bp+ ´07
V70 2.5 FT A ´10
wla
torque kirjoitti:sivulinja kuin jokin audi-seat exeo mukaelma. Keula suoraan Koreasta.
Aika geneerinenhän tuo on,mikä kiinalaisilta ei ole sinänsä yllätys.
Aina joku Saabbi...
Rattivaihde
Mielenkiintoinen sekoitus Subarua (keula), Bemaria ja Audia (kylki/takavalot) sekä Volvoa (värisävy) ja Saabia (etupuskurin alaosa). Sisustakin on juuri niin yleismallinen kuin odottaa saattaa, starttinappula keskikonsolissa ja ympärillä nappuloita VAG-tyyliin, mittaristo Lexuksesta, ilmasuuttimet Subarusta.
#5168
Saab 900c Combi Coupé '89
ng900aero
Ihan siistinnäköinen luomus, ja moinilta osin paranneltu alkuperäisestä kuten mm. vihdoin ja viimein on ikkunoiden ja peilien säätimet oikeassa paikassa, mittaristo näyttäisi sellaiselta että sen saa irti ilman koko kojelaudan purkamista ja istuimet näyttävät viimeistellyimmiltä kuin Saabin istuimet, ja luultavasti ovat parempilaatuista nahkaakin?
Sensijaan tuo navi/mikälie viihdenäyttöpaneeli on edelleen ihan väärässä paikassa, sen pitäisi olla BMW:n tyyliin ylhäällä. Nyt on ympätty tuohon vaihdekepin taakse (eli paikkaan johon kuuluu laittaa hanskat, pipo ja kaulahuivi) starttinappulan lisäksi noita istuinlämmityksen ja -tuuletuksen, jne -numikoita. Eikö noita osaa edes kiinalaiset sijoittaa kojelautaan tai siis keskikonsoliin? :)
Tosi kallishan tuo on, Suomeen tuotuna ja verotettuna varmaankin samanhintainen kuin OG 9-5.
Riittääköhän tuolle femman kolaritestitulokset vai joutuvatko teettämään Euroncapin testit uudestaan, vaikka kyseesä vain isompi facelift samalle autolle?
Saab 9-3 SC TTiD -08
Saab 9-3 Cabrio 1.8t -06
Ducato Maxi -98
SS
Toivottavasti eivät edes yritä tuupata romujansa tänne.
Näyttääpä muuten olevan Night Panel -nappi starttinapin vieressä :D
Muuta: Kiina TECH2
Risto
Viesti Kirjoittaja Risto »
Sivun oikeassa reunassa Sportive Super Cars: Maserati, Bugatti, Ferrari, Saab 9-3 SS jne. :D
