Does anyone know where I can get some polybush type anti roll bar bushes for a 96V4???
Tietääkö kukaan mistä voin saada joitakin polybush tyyppi anti kallistuksenvakaaja pensaita, 96V4??
Chris
England
						Anti Roll Bar bushes
Re: Anti Roll Bar bushes
Haluaakohan hän siis kallistuksenvakaajan puslia vai tukivarren puslia ?
eipä niitä saanut 89 luvullakaan olisko jollakin uus tuotantoa? siksi ne lensikin helveddiin ennen leimaa kun hylky olisi tullut muuten
Etsin POLYBUSHES etu-anti kallistuksenvakaaja ja 1975 96V4
Im using Google Translate to do this ,I hope it is right
Chris
England
Chris
England
Well, google translator doesn't always produce understandable language, especially on words that have multiple meanings on either language
The guys are wondering whether you are looking for the D-shaped anti-roll bar rubber bushes or the bushes for upper or lower wishbones? Are you looking for original type bushes or harder polyurethane ones?
I have a 1962 two-stroker and that does have an anti-roll bar that is supported to the chassis by two D-shaped rubber blocks that have a hole through them. If I remember correctly the laver V4's (at least 1974 and 1975 that I used to have) did not have any anti-roll bar as standard.
The upper and lower wishbone bushes are available (probably even in PU for rally use) but I am not aware of anyone producing the anti-roll bar bushes, of course they may still exist.
For instance Veteranshop.se has the wishbone bushes (The prices are in SEK):
- Upper wishbone ( http://shop.textalk.se/se/article.php?i ... grp=195527 )
- lower wishbone ( http://shop.textalk.se/se/article.php?i ... grp=195527 )
Tahtari-Pekka
95, 1962 (MA) - 900 OG, 1984 (MA)
Since the Saab anti-roll bar bush and its mounting is fairly simple I think I would look whether similar bush has been used on some other car as well.
A simple search shows for instance that Ford Escort rear anti roll bar bushes look really similar to the ones that I have on my stroker. If the bush hole dimension is correct but the mounting dimensions are a bit different, one can quite easily fabricate the required mounting clamp for the dimensions suitable for the new bush.
http://www.polybush.co.uk/shop/view/265 ... cort_(MK1)
Tahtari-Pekka
`Kabu`, thanks for the reply,I can confuse most English people
 . The bushes I am looking for are the D shaped ones and the ones for the end of the ARB, I have replaced all of the suspension bushes with Polyurethane ones and this is what I would like for the ARB. I have looked at other model applications and the Escort is near to it, the D shaped one has a hole of 13mm and is 45mm high and the end one would have the same size hole and be approximately 30mm long.
Chris
						Chris
