Looking for turbo
Lauri LV
Looking for turbo
Viesti Kirjoittaja Lauri LV »
Hi everyone
My 9000 aero turbo broke down, maybe someone have spere turbo and can sell it to me?
I have - TD04HL-15G mitsubishi turbo
SAAB 9k aero
9-3 aero
Kupari
Re: Looking for turbo
Viesti Kirjoittaja Kupari »
What year is your 9000?
That 15g is found only in long block engine year -93 2.3l Aero and quite difficult to find even used.
You can replace it with short blog engines 94-98 2.3l Aeros 15t which are much easily to found and bolt on. Water and oil pipe maybe little fixin and on my car -93 changin garret t25 to Aero 15t just 2 rubber hose just needed .
These 15t cost new 900€ and 15g i dont know are those in Finland even for sell.
Used 15t i found for myself by putting advertisement to bying saab parts topic under week.
Jäsen 2986
Lauri LV
Kupari kirjoitti:What year is your 9000?
Hi
I have 93 year, 1993 03 03. And yes I have long block engine.
Yea I understand that it will be difficult to find new that’s way I whaned to know some shops who repair turbos and know how much cost to rebuilt it, ore to find used one, but maybe somebody can tell me how big even can put turbo on my tronic 5.2 engine?
i whanted bigger but not to big.
And whis turbo what is broken in my car sounds like daying elephand in hot summer day :D :D
SAAB 9k aero
9-3 aero
Kupari
Fin-turbo, Pro turbo,, turbohuolto Riikonen,etc. Put word turbohuolto in Google and it shows many places fixing turbos.
My longblock -93 2.3T trionic 5.2 with old (runned 260tkm) mitsubishi aero 15t using bensin 98E taken out 261hp/422Nm. I have compared to your car bigger cooler, 3" dp and racecat, 2,5" catback pipes. Software for me was made on rolls by vesa67.
There are some klubmembers (like vesa67, jcarlson, nappe, hook, coltti etc) who can tell you is there strait software if you want bigger like mitsubishi 19T or 20T wich are almost bolt on to put. I know that those members upper have made them for others..Without fitting software and other needed changes bigger than 15t is very dangerous for the engine.
I still have in garage -93 Aero (mitsu 15G) ecu and it works in my car with that 15t very good, better than original 2.3T (garret t25) software.. That now driven custom software was put in different ecu.
With 19/20T you need 3" dp, racecat and 2,5" of 3" pipes, maybe 3bar Map, bigger injectors etc. Needed changes also depends If you use bensin or want to change using etanol. There are some -93 trionic 5.2 changed to using etanol said Vesa to me.
Shortblocks 94-98 trionic 5.5 softwares are not fitting because ecu memory, injectors and few things in engine are different on -93 trionic 5.2
Jäsen 2986
Lauri LV
Yea I understand that all, and I have 3” downpipe and strait 3” exsoust, same as Vesa change my ECU to stage 1 with e85 (ethanol)
SAAB 9k aero
9-3 aero
Kupari
Ok.
With etanol and bigger turbo like mitsu 19T injectors must be also bigger. If Vesa made your stage1 you can ask him what is needed.
Near my hometown is Pro Turbo and i have bought one mitsu 19T for ng900 there. Now i have one volvo s40 mitsu 12t wich i will take there to repair and changed to bigger 14t. Changin and repairing is between 400-500€ when i asked.
Jäsen 2986
Lauri LV
Kupari kirjoitti:Ok.
About pro turbo, I asked them in messige how much cost ore repais my turbo ore buy from them new and all time if I ask something about money they don’t replay me.
SAAB 9k aero
9-3 aero
Kupari
Ok. I visit Pro turbo personally and showed 12t , it is by the road going to central hospital so on same driving it was easy to go. They said that it can be repaired and cost are little cheaper than new one. Finally cost depends how much they have to repair and that can be seen only after opening turbo.
Jäsen 2986
Lauri LV
Kupari kirjoitti:Ok. I visit Pro turbo personally and showed 12t , it is by the road going to central hospital so on same driving it was easy to go. They said that it can be repaired and cost are little cheaper than new one. Finally cost depends how much they have to repair and that can be seen only after opening turbo.
Yea same told me in latvia turbo repair shop ok thanks for help :)
SAAB 9k aero
9-3 aero
