Tyyppikilven tulkintaa
Vuonna 2010 markkinoille tullut täysin uusi 9-5.
Tonnari88
Viesti Kirjoittaja Tonnari88 »
Moro,
Ajattelin, kun ei tähän malliin ole vielä koostetta, mikä avaa tuon tyyppikilven kuten NG 9-3:ssa niin koostetaan sellainen. Kun saadaan tämä täydennettyä, niin ylläpito voisi jopa kiinnittää tämän julkaisun. Tyyppikilpi löytyy siis kuskin ovikotelon sisältä.
Etujouset
F0 Front spring||With Front Wheel Drive (FWD) Standard front strut Except lowered sport chassis 12822720
F1 Front spring||With Front Wheel Drive (FWD) Standard front strut Except lowered sport chassis 12822718
F2 Front spring||With Front Wheel Drive (FWD) Standard front strut Except lowered sport chassis 12822722
F3 Front spring||With Front Wheel Drive (FWD) Standard front strut Except lowered sport chassis 12822724
F4 Front spring||With Front Wheel Drive (FWD) Standard front strut With lowered sport chassis 12822721
F5 Front spring||With All Wheel Drive (XWD) Standard front strut With lowered sport chassis 12822726
F6 Front spring||With All Wheel Drive (XWD) Standard front strut With lowered sport chassis 12822727
F7 Front spring||With Front Wheel Drive (FWD) Standard front strut With lowered sport chassis 12822723
F8 Front spring||With Front Wheel Drive (FWD) Standard front strut With lowered sport chassis 12822725
F9 Front spring||With Front Wheel Drive (FWD) Standard front strut With lowered sport chassis 12822719
FA Front spring||With Front Wheel Drive (FWD) Performance front strut Except lowered sport chassis 12824049
FB Front spring||With Front Wheel Drive (FWD) Performance front strut Except lowered sport chassis 12824050
FC Front spring||With Front Wheel Drive (FWD) Performance front strut With lowered sport chassis 12824051
FD Front spring||With Front Wheel Drive (FWD) Performance front strut With lowered sport chassis 12824052
Takajouset
R0 Rear spring||Except lowered sport chassis 13310867
R1 Rear spring||With lowered sport chassis 13310868
R2 Rear spring||Except lowered sport chassis 13310869
R3 Rear spring||With lowered sport chassis 13310870
R4 Rear spring||With Front Wheel Drive (FWD) Except lowered sport chassis 13310873
R5 Rear spring||With Front Wheel Drive (FWD) Except lowered sport chassis 13310874
R6 Rear spring||With Front Wheel Drive (FWD) Except lowered sport chassis 13310875
R7 Rear spring||With Front Wheel Drive (FWD) Except lowered sport chassis 13310876
R8 Rear spring||With All Wheel Drive (XWD) 13310878
R9 Rear spring||With All Wheel Drive (XWD) 13310879
Etuvakaaja
S1 Stabilizer bar||Standard front strut Except lowered sport chassis Without continuous damping control Oe 20932137
S0 Stabilizer bar||Performance front strut Without continuous damping control Except lowered sport chassis OE 13230517
SG Stabilizer bar||Standard front strut With lowered sport chassis Without continuous damping control OE 20932138
S9 Stabilizer bar||Standard front strut With lowered sport chassis With continuous damping control OE 20932136
SA Stabilizer bar||Performance front strut With lowered sport chassis With continuous damping control 13230520
Takavakaaja
S5 Stabilizer bar||Except lowered sport chassis Without continuous damping control With Front Wheel Drive (FWD) 13281795
S6 Stabilizer bar||With lowered sport chassis Without continuous damping control With Front Wheel Drive (FWD) 13281796
S7 Stabilizer bar 20959230
S8 Stabilizer bar 20959231
Etuiskari
75 Spring strut||Standard front strut Without continuous damping control With Front Wheel Drive (FWD) 12822730 12822731
76 Spring strut||Standard front strut Without continuous damping control With lowered sport chassis With Front Wheel Drive (FWD)
77 Spring strut||Standard front strut Without continuous damping control With Front Wheel Drive (FWD) Except lowered sport chassis
78 Spring strut||Standard front strut With lowered sport chassis Without continuous damping control With Front Wheel Drive (FWD)
79 Spring strut||With All Wheel Drive (XWD) Standard front strut With lowered sport chassis Without continuous damping control
80 Spring strut||With All Wheel Drive (XWD) Standard front strut With lowered sport chassis Without continuous damping control
83 Spring strut||With All Wheel Drive (XWD) Performance front strut With lowered sport chassis Without continuous damping control
84 Spring strut||Performance front strut Without continuous damping control With Front Wheel Drive (FWD) Except lowered sport chassis
85 Spring strut||Performance front strut Without continuous damping control With lowered sport chassis With Front Wheel Drive (FWD)
86 Spring strut||Standard front strut Without continuous damping control With Front Wheel Drive (FWD) 13333018 ja 13333017
C0 Spring strut||Standard front strut With continuous damping control With lowered sport chassis With Front Wheel Drive (FWD)
C1 Spring strut||Performance front strut With continuous damping control With lowered sport chassis With Front Wheel Drive (FWD)
C2 Spring strut||With All Wheel Drive (XWD) Standard front strut With lowered sport chassis With continuous damping control
C3 Spring strut||With All Wheel Drive (XWD) Performance front strut With lowered sport chassis With continuous damping control
Takaiskari
84 Rear shock absorber assy||Without continuous damping control Except lowered sport chassis 12822746 12822745
85 Rear shock absorber assy||Without continuous damping control Except lowered sport chassis 13331846 13331845
86 Rear shock absorber assy||With lowered sport chassis Without continuous damping control 13331848 13331847
87 Rear shock absorber assy||Without continuous damping control With lowered sport chassis 13331850 13331849
88 Rear shock absorber assy||Except lowered sport chassis With Front Wheel Drive (FWD) Without continuous damping control 12822742 12822741
89 Rear shock absorber assy||Except lowered sport chassis With Front Wheel Drive (FWD) Without continuous damping control 12822744 12822743
90 Rear shock absorber assy||With Front Wheel Drive (FWD) Without continuous damping control With lowered sport chassis 13331856 13331855
91 Rear shock absorber assy||With Front Wheel Drive (FWD) Without continuous damping control With lowered sport chassis 13331858 13331857
92 Rear shock absorber assy||Without continuous damping control With lowered sport chassis With All Wheel Drive (XWD) 13331860 13331859
93 Rear shock absorber assy||Without continuous damping control With lowered sport chassis With All Wheel Drive (XWD) 13331862 13331861
C6 Rear shock absorber assy||With lowered sport chassis With Front Wheel Drive (FWD) With continuous damping control 13313445 13313444
C7 Rear shock absorber assy||With lowered sport chassis With All Wheel Drive (XWD) With continuous damping control 13313447 13313446
C9 Rear shock absorber assy||With continuous damping control With lowered sport chassis With Front Wheel Drive (FWD) 12823606 12823605
Etujarrulevyt
AF: 16" 296mm
AG: 17" 321mm
AH: 17"+ 337mm
AE: 18" 345mm
Takalevyt
BD: 16" 292mm
BE: 17-18" 315mm
Etusatulat
CA: 16"
CB: 17"
CC: 17"+
CD: 18"
Takasatulat
DA: 16"
DB: 17-"
9-5 NG | 9-3 SC | 9-3 Aero | 95 V4 | Exät | 9-3 SC TiDs | 9-5 Aero | 900 Turbo T8 x 2 | 9-3 SE | 9000 CS x 4 |
"Having a fast SAAB is like coming out of the closet, you might surprise people, but you're still gay"
tturku
Re: Tyyppikilven tulkintaa
Viesti Kirjoittaja tturku »
Kiitos, tämähän on jo hyvä näin ja paremmaksi muuttuu jos päivitetään joten laitoin pysyväksi samantien.
Latezi02
Viesti Kirjoittaja Latezi02 »
Kysymys saattaa olla tyhmä, mutta kysyn silti. Mitä eroa on 84 ja 85 takaiskareilla? Omani on 84 enkä meinaa löytää sellaisia mistään. Löysin tuolla 85 numerolla esim R&D car partsin sivuilta sellaisen joka väittää sopivansa 85,86 ja 87 autoihin, mutta eivätkös nämä ole keskenään erilaisia. Miten siis voisi sopia 85 ja 86 mutta ei 84?
Latezi02
Päivitystä edelliseen: Löysin lopulta kyseisestä kaupasta myös tuon 84 koodin iskarit (auttoi kun kirjotti osanumeron oikein), joten aikaisempi kysymys lopulta turha joskin silti mielenkiintoinen. Köyhdyin 360€ posteineen ja veroineen noista iskareista ja ajattelin kiusata itseäni sitten vielä vähän lisää katsomalla motonetista mitä maksaisi A-Insignian iskari... 73€ kpl ja lähi liikkeen hyllyssä. Kuvan perusteella myös melko saman näköinen, joten ehkä hieman jäi mietityttämään voisiko ooppelin osa käydä suoraan. Saa kommentoida jos on tietoa.
