automatic transmission
flying dutchman
- "Kaasari"
Hi all. I'm sorry i have to write in english to this site, but i live so shortly in Finland that i can't do it in finnish yet. I just moved here a year ago from Holland. I hope some of you still can help me sometimes with my guestions over my saab 900 t8 from -84. If it's impossible to answer in english, you can also do it in finnish and my wife'll try to translate it into dutch for me.
Question:
my saab's automatic transmission is not working quite well. The reverse is not working at all. In all other positions the car goes forward, including neutral. Does someone know what can be the problem? Does anybody have an instruction manual of that automatic gear box, cause i might try to fix it myself.
-flying dutchman- not flying yet..
Question:
It's quite a daunting task to fix it yourself, but the first thing you should do is to check the oil level per the instructions written in the user's guide.
If the oil level is right, the problem is probably in the "worm box", ie. the hydraulic computer of the gearbox. Some flap or spring is missing or dead.
Ville Jouppi #1780
flying dutchman
- "Kaasari"
Hi
thanks for you'r reactions ,the link of the saabsite i already have and there is not much that can help me with my problem,do it's i nice site to help you with many problems.
The worm box is that the front part of te transmission where is also the torque converter?
Gr:Ed
Gr:Ed
-flying dutchman-
flying dutchman
- "Kaasari"
Saabpics server doesn't seem to respond today, but usually it's been quite stable and always available. Try again later. There are four or five pages of troubleshooting instructions from service manual - don't know if they help at all in your problem.flying dutchman kirjoitti:thanks for the link but ,i'ts not opening somehow?
flying dutchman
- "Kaasari"
ok.the site already works again, i was too unpatient...........anyway i think i can try some things now.
thanks so far.
GR Ed
thanks so far.
GR Ed
-flying dutchman-
flying dutchman
- "Kaasari"
Gearbox problem 2
Hey, about a year ago i asked some questions hoping to solve the problems of the aut...transmission of my T8.
Well now i came to the conclusion that it's better to change it for a manual gearbox.
So i got my selve a spare car and got started...but now i need a new gasget that comes between the motor and manual gearbox.
The Saab dealer in Kuopio does not have one ,and said that thay can't order new anymore becouse the factory does not make them anymore
Does some one perhaps know where i can find one and how much a gasget like that costs.
Greetings Edwin.
If you prevere to answere in suomi, my wife can translate it for me.
Greetings Edwin.
-flying dutchman-
V.J.S
Hi,
you may order one from http://www.motonet.fi:
ÖLJYPOHJAN TIIVISTE SAAB 900 79--93
8V-moott (vaihteiston/moottorin väliin) paperitiiv.. . . . 27-1508 3.00€
As you can see, the gasket costs 3€, I'd put also some Loctite gasket glue with it.
-Ville
-Sähkövatkain model Y -24
-Luottopeli Pösö 307 1.6 -03
flying dutchman
- "Kaasari"
No matter does the gearbox come from 8v or 16v engine, theres no radical differencies with gasgets, but see below.
As for sealing the engine-gearbox-interphase, I would go also with some silicone sealant/gasget glue which can tolerate ~300C temperatures and oil. I used only gasget glue in last two transmission swaps, works great. IMO it is almost better solution then the paper/metal gasget.
flying dutchman
- "Kaasari"
