Takaoven verhoilun irroitus
9000 cs -94
Viesti Kirjoittaja 9000 cs -94 »
9000 cs:n takaovenlukitusnapin rikoin pakkasella,ohjeet viasta ja korjauksesa löytyvät, mutta miten saan oviverhoilun irroitettua ehjänä?
TT
Viesti Kirjoittaja TT »
Tuollaiset ohjeet löysin joskus kun piti irroittaa toisen takaoven verhoilu ja noilla se onnistui jopa niin, ettei jäänyt montaa ylimääräistä ruuvia kun ovi oli pistetty takaisin kasaan...
1. Remove light in door by removing screw with T10 Torx tool. Slide light assembly out and remove wires.
2. Remove screw in hole where the light is mounted with T25 Torx tool. (This one is kind of hidden behind insulation material)
3. Remove oval panel under door handle. Pry gently (from the front to the rear) and it will pop out.
4. Remove screw holding plastic trim around door handle with T25 Torx. After screw is removed, the trim piece can then be taken off.
5. Remove round plug in top and bottom of door pull handle. (Pry them to get them started then slide them out)
6. Remove both screws from top and bottom with T25 Torx. (Don’t try to pull the handle off.)
7. Remove the covers on the bolt heads on either side of the door pocket.
8. Remove the uncovered bolts with T25 Torx.
9. Pop the bottom of the door panel off pulling it towards you. There are white nylon inserts that hold it to the door frame..
10. Raise the door panel up to loosen it from the top window sill.
11. The door panel should be free at this point.
Remove the mirror switch panel (or blank panel). For 91 style: Pry at the bottom or top, pop out at the rear.
For 93 and later, insert a small screwdriver into the hole behind the mirror select switch and pry the tab forward.
Remove T20 Torx screw.
Pull door handle out, slide plastic backplate down and rotate out from bottom.
Remove soft plastic plugs from top and bottom of door pull.
Remove T20 screws from top & bottom of door pull.
Use a small flat blade screwdriver to pop the plastic caps off the two screws at front and rear of storage bin.
Remove weird-headed T20 screws from front and back of storage bin.
Remove T10 screw from door light lens. Slide lens back and out.
Remove T20 screw from the bracket for the lens retaining screw You might have to fish through some insulation to find it.
Work a flat tool up under the bottom of the panel, then work fingers back and pull to disengage the plastic pop-retainer at the bottom rear corner. Repeat at front, about 8" from bottom.
Pull the panel up out of the window through at the top; this can take quite a bit of force, as there are metal tangs to resist its removal. Push from the bottom and thump lightly from below to break it loose. Remove the wires from the light before completely removing the door panel.
9-3 Aero -01
9000 cs -94
Kiitos,
irroitusonnistui jo Mimmin lyhennetylläohjeella. Kuten haulla löytyneissä keskusteluissa, oli minullakin lukitusnapin muovinen kiinnike poikki, uusi tulee huomenna, hinta oli Länsiautossa jopa 1,40€ (aiemmin oli joku saanut 0,5€ hinnalla; huima korotus, mutta eiköhän tuo korjausbudjetti kestätuon.
