Uusi diesel -moottori 9-3SS:ään
Turbo Sensonic
9-3 SS:ään on tulossa uusi diesel -moottori. Tässä tietoa moottorista.
-Lähde Saab Media Online
Latest Diesel Technology For Saab 9-3 Sport Sedan
'State-of-the-art' common rail, direct, multiple injection 1.9TiD unit
New levels of performance, refinement and economy
Reinforces sporty, fun-to-drive 9-3 Sport Sedan chassis dynamics
Raises Saab's offer in premium diesel segment
Available with 150 bhp/315 Nm or 120 bhp/280 Nm
Six gear manual gearbox as standard
Segment-leading six-speed auto option
Innovative maintenance-free particulate filter, Euro 4 compliance
The Saab 9-3 Sport Sedan's widely-acclaimed, 'fun-to-drive' chassis dynamics are now complemented by the addition of a 'state of the art' 1.9TiD powertrain. The combination is expected to significantly raise Saab's penetration of Europe's growing diesel segment.
Delivering more performance, more refinement, lower emissions and better fuel economy, this sophisticated powerplant endows the 9-3 Sport Sedan range with a compelling choice in the premium diesel segment that is as attractive and competitive as its gasoline offer.
The new common rail, direct and multiple injection engine is configured for 150 bhp or 120 bhp. But, even more importantly, it offers a wide spread of strong pulling power, with 90% of the generous maximum torque available all the way from 1,750 to 3,250 rpm. It also raises the 'state of the art' by introducing a maintenance-free particulate filter that ensures compliance with Euro 4 emission standards, effective from 1 January 2006.
Offered in Arc, Linear and Vector variants, it is fitted as standard with a six-speed manual gearbox, as well as the option of a six-speed automatic transmission for the 150 bhp version, a 'first' in the segment.
Sparkling performance
The 16-valve, 150 bhp version is focused on delivering enhanced performance, while the 8-valve, 120 bhp configuration places a greater emphasis on the cost of ownership.
Compared to the 2.2TiD unit it replaces, the 150 bhp 1.9TiD engine offers 20 per cent more power and 12.5 per cent more torque, as well as greater running refinement and improved fuel consumption. Increased power translates to sparkling on-the-road performance. In-gear acceleration, the most important feature for everyday driving, is on a par with the top-of-the-line 9-3 Aero model while the zero to 100 kph dash, of rather less importance, is still accomplished in a brisk 9.5 seconds.
The 8-valve version returns fuel economy of 5.8 liters/100 km* over the combined cycle, a useful 12 per cent improvement against the outgoing 2.2TiD. CO2 emissions of 157 gms/km* show an 11 per cent reduction.
Both share the same four cylinder, cast-iron block and an alloy cylinder head. There are twin, chain-driven, overhead camshafts and hydraulic tappets for the 16-valve engine and a single camshaft for the 8-valve format. Both have a steel crankshaft and connecting rods, a dual-mass flywheel, a weight-saving pressure cast aluminum intake manifold and electronically-controlled exhaust gas re-circulation (EGR) for quick warm-up and low emissions.
Common rail technology provides consistently high injection nozzle pressures of 1,600 bar, independent of the prevailing engine speed or load. This platform allows the use of small, multiple injections of fuel, between two and five, to release as much energy as possible from a given amount of fuel.
This extremely efficient combustion process pays dividends in a number of key areas. Apart from improving fuel consumption, emissions and power, it is crucial in helping to iron out the strong vibrations traditionally associated with compression ignition.
The Bosch ECM continually adjusts the number, frequency and size of the injections according to three main parameters: current engine speed, requested throttle setting and engine coolant temperature. Each injection pulse may be separated by as little as 150 microseconds, delivering a quantity of fuel as tiny as one cubic millimetre.
Typical Saab turbo power
On the road, both 1.9TiD engines have a distinctly sporty character, further narrowing any perceptible difference between diesel and gasoline engine performance levels - except in the frequency of visits to the filling station.
Saab turbo engines have always been characterized by an extremely strong and wide spread of torque, giving the kind of low and mid-range power that is needed in everyday driving. The 1.9TiD engine delivers just this kind of performance, demonstrated by the fact that 90% of maximum torque, an impressive 315 Nm for the 150 bhp engine and 280 Nm for the 120 bhp version, is generated between 1750 and 3250 rpm.
Furthermore, the driving experience is enriched by a smoothness and refinement, together with a progressive torque build-up, that belies the presence of compression ignition. Engineers have helped to achieve this by calibrating the movement of the electronic throttle to deliver a response similar to Saab's gasoline engines. The process is optimized by a low-inertia, intercooled Garrett turbocharger, operating at 1.35 bar boost, which includes variable vane geometry (VNT) where the pitch of turbine blades is electronically adjusted for quick pick-up at low engine speeds.
Low levels of NVH (noise, vibration and harshness) inside the car are due to the engine's advanced combustion technology as much as its careful chassis installation. This includes the adoption of an electro/hydraulic power steering system, for improved fuel consumption, and additional tuning of the front suspension and wheel angles.
Six-speed transmissions
The high level of driving satisfaction is reflected in the standard fitment of a close-ratio, six gear manual gearbox that encourages driver involvement and complements the 9-3's sporty handling characteristics.
The optional six-speed Aisin AW automatic transmission for the 150 bhp engine is a 'first' for Saab and unique in this segment of the market.
It is a smooth and adaptive unit, responsive to changes in engine load, road gradient or altitude, and quickly finds the ‘right’ gear without any irritating ‘hunting’. It features lock-up in all forward ratios, except first. The driver can also switch to manual control by using a sequential floor shift or optional steering wheel mounted buttons.
Innovative Particulate Filter
The 1.9TiD powertrain includes the most advanced diesel particulate filter on the market, enabling Euro 4 emissions compliance, an essential requirement for many company car drivers. Unlike other particulate traps, it is maintenance-free and self-cleaning, requiring no additives or periodic replacement.
Located in the exhaust system downstream of the close-coupled catalyst, the housing for the filter also includes a secondary oxidation catalyst to remove residual hydrocarbons (HC). The exhaust gases pass through this first, before entering the filter's ceramic core, made from a honeycomb of silicon carbide. This is perforated along its length by a matrix of microscopic channels, which collect the particulates as deposits from the exhaust.
In order to clean the filter and to keep the exhaust flow as free as possible, these deposits are periodically burnt off by short pulses of over-fuelling. These briefly raise exhaust temperatures to the required level of 600º C. The process is automatically initiated when back pressure in the exhaust system reaches a certain level and is completely undetectable by the driver.
This innovative solution has been made possible through the fuelling flexibility provided by the engine's multiple injection strategy. The self-cleaning process takes place whenever necessary, irrespective of throttle load or engine temperature.
Specifications, performance and fuel consumption
1910 cc. Four cylinders. Aluminum cylinder head and cast iron block. DOHC 16v / SOHC 8v. Common rail, direct and multiple injection.
Turbocharged, VNT; intercooled. Dual-mass flywheel.
Front transversely-mounted, front wheel drive.
Euro 4 Emissions (Jan 06) compliant
Maintenance-free particulate filter.
Scheduled Service intervals, 25,000 km.
Developed by GM-Fiat Powertrain, produced at FMA plant, Italy.
1.9TiD 8v 1.9TiD 16v
Max. power 120 bhp (88kW) @ 4,000 rpm 150 bhp (110kW) @ 4,000 rpm
Max. torque 280 Nm @ 2,000 - 2,750 rpm 315 Nm @ 2,000 - 2,750 rpm
Bore/Stroke (mm) 90.4/82 90.4/82
Compression ratio 18:1 15.5:1
Max boost pressure 1.35 bar 1.35 bar
Ignition/Fuel injection Bosch EDC 16. Ignition / fuel-injection system.
Performace 1.9TiD 8v* 1.9TiD 16v
0-100 km/h (sec) M6 11.5 M6 9,5 A6 11.0* 80-120 km/h 5th gear (sec) M6 12.5 M6 12.5 A6 N.A.
Top speed (km/h) M6 200 M6 210 A6 210*
Fuel consumtion 1.9TiD 8v* 1.9TiD 16v
Urban (l/100 km) M6 ** M6 7.7 A6 **
Extra Urban (l/100 km) M6 ** M6 4.9 A6 **
Combined (l/100 km) M6 5.8 M6 5.9 A6 7.2*
CO2 (g/km) M6 157 M6 169 A5 194*
M5 = five-speed manual gearbox
M6 = six-speed manual gearbox
A6 = six-speed automatic gearbox
* Preliminary figures
** Final figures not yet available
Kuvia:
Isompia kuvia:
http://194.18.30.108/smo/smopics/0/04400C.JPG
http://194.18.30.108/smo/smopics/0/04401C.JPG
Vielä isompia kuvia:
http://194.18.30.108/smo/smopics/0/04400D.JPG
http://194.18.30.108/smo/smopics/0/04401D.JPG
#1438
NG9-5 2.0TTiD 3/2011
NG9-3CV 1.9TiD 7/2007
potkuhousu
ei siell moottorissa lue missään OPEL :lol:
Jyrki alias potkuhousu
SS-K #1636 STCF #2
Rommitommi
Toi kuulostaa muuten tosi hyvältä, mutta vähän Fiatin tekniikka arveluttaa :roll:
pertti666
Viesti Kirjoittaja pertti666 »
Mutta Mutta...mites kun jostain luin että OPEL esitteli samankokoisen uutuusdieselin just hetki sitten, eikä ko artikkelissa minkä luin (ei muista mikä suomalainen autolehti oli, itteasiassa veikkaan AUTOBILDIÄ)(eihän se kyllä oo suomalainen varsinaisesti :roll: ) mainittu sanallakaan FIATia, eli onko nyt kuitenkin näin että OPEL, FIAT - ALFA JA SAAB käyttää samaa konetta vai eikai GM:n talousosasto keksinyt kuluttaa vähiä varojaan kahteen eri diesel moottoriprojektiin?
9-3 SC 2.0t vector -07
# 1781
Rommitommi
Re: Uusi diesel -moottori 9-3SS:ään
Turbo Sensonic kirjoitti: Developed by GM-Fiat Powertrain, produced at FMA plant, Italy.
Ton perusteella aattelin, että olisi Fiatin kehittämiä, mutta tiedä sitten...
Ainakin http://www.opel.de sivuilla on mainittu myös tuo sama moottori, joka tulee SS:ään...
pertti666
Rommitommi kirjoitti:
juu kyseessä on näköjään yksi ja sama moottori, mutta kun toi artikkeli mihin viittasin "aiemmassa puheenvuorossani" oli Autobildistä luettu = saksan versiosta suomennettu, niin onhan se näin ettei Lapin polttajan jälkeläiset voi myöntää että OPEL-merkkisen auton moottorin kehitystyössä olisi muitakin mukana ollut 8O , kansallistunto on kummunnut kun Opel on kutsunut saksalaistoimittajat tutustumaan uuteen moottoriin, eikä toimittaja ole enää katsonut aiheeksi mainitaan italia-connectionista mitään..
# 1781
9-3Tid
Viesti Kirjoittaja 9-3Tid »
sama se kuka ne moottorit tekee, makaroonimaan tekosia ne taitaa olla. Ihmetyttää tuo, että pitää laittaa noin pientä moottoria pellin alle ja lyödä vaan ahtoja lisää...nyt 1.35bar, vs. 2.2tid 0.9bar. Suunta on muilla merkeillä jo aivan toinen. Jos vanhaan myllyyn löis noi ahdot ja rukkais syöttöä lisää ja vaihtais isompaa turboa niin liikuttais aivan muissa lukemissa!
KARELPA
Viesti Kirjoittaja KARELPA »
Tässä näyttäs olevan pakosarja oikealla puolella moottoria eli turbo olis lohkon ja syylärin välissä eikä niinkuin nykyisissä nakuissa
9-5 Aero
Opel Omega 2.2 DTH
Kawasaki ZZR 1100
mikkoma
Saab 9-3SS 1.9 turbodiesel
Viesti Kirjoittaja mikkoma »
Perjantain iltalehti koeajoi uuden Saab9-3SS 1.9td ja kehui moottoria ja autoa ihan mukavasti.Mielestäni Fiat on tehnyt ihan hyviä dieselmoottoreita pitkän aikaan ja varmaan ihan hyviä esim.Opelin vastaaviin moottoreihin verrattuna. Suorituskykyä ja kulutusta pidettiin hyvänä.
Terv. Mikkoma
ajokoira
Opel
Viesti Kirjoittaja ajokoira »
Dieselkone oli testissä Vectran korissa AutoBildissä. Kehuivat koneen hiljaisuutta...toivottavasti tuli ysi-viitoseenkin tollainen diesel.
#6058
9³ Aero Cabriolet 2002
Kansanautoja 2 kpl
ex 9⁵ 2.0T Vector Sport Wagon 2003
