vikakoodi??? Saab 9-3 farmari vm.2006 1.8turboo
Pedro_diniz
Viesti Kirjoittaja Pedro_diniz »
Saabi vilkuttelee luistonesto valoa.
Kun laittaa virrat päälle mittaristoon syttyy luistonesto valo ja ei sammu
ennenkuin kuittaa sen ajotietokoneen nappulasta. Onko normaalia vaiko eikö?
Vikakoodit on luettu ja ainut mitä ilmoittaa on:
Ohjainlaitediagnoosi SAAB ESP TRW 430 vikamuisti C0131 painetunnistin viallinen.
Onko kenelläkään ollut autossa samaa ongelmaa?
Kiitos jo etukäteen
Saab 9-3 2.0 T5 E85
wizard11
Re: vikakoodi??? Saab 9-3 farmari vm.2006 1.8turboo
Viesti Kirjoittaja wizard11 »
Pedro_diniz kirjoitti:Saabi vilkuttelee luistonesto valoa.
Kiitos jo etukäteen
Jep C=chassis jne...
OBD-II codes consist of a number of parts. Here is a sample OBD2 code:
P0171
Here is a breakdown of what each digit of the code means:
First Character - System
The first character identifies identifies the system related to the trouble code.
P = Powertrain
B = Body
C = Chassis
U = Undefined
Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code.
0 = Generic (this is the digit zero -- not the letter "O")
1 = Enhanced (manufacturer specific)
Third Digit - Sub-System
The third digit denotes the type of sub-system that pertains to the code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Fourth and Fifth Digits
These digits, along with the others, are variable, and relate to a particular problem. For example,a P0171 code means P0171 - System Too Lean (Bank 1).
Kunnon coolerista ilo irtoaa... ZPF-*** Aero
VKe
Viesti Kirjoittaja VKe »
TC failure or was it..?
Grrreat. According to OBD it's a Generic chassis emission management failure...
Tells nothing - no added value or am I wrong??
