A***** kärähti kopioinnista
http://www.maptun.com/pirates.php
TUNING PIRATES
An English tuning company use illegal copies of Maptun software, and label them as their own!
Maptun hereby want to inform that an English tuning company sells Maptun's stage1 software for the Saab 9-5 2,0 LPT (B205E), and has also sold copies of our stage 3 software for the 9-3 Viggen (B235R). We do not yet know if this company has copied and sold Maptun software for other Saab models, but are of course investigating the matter further.
The last incident was when an exchange unit was returned to us from a customer in Asia. This exchange unit was supposedly a stage 1 software for the 9-5 B205E engine from the English Saab tuner, but the software in the ECU was a 100% PURE COPY of our stage 1 for the same model.
Every single MAP and parameter (exept the Win number) was identical with Maptun's software and it also has Maptun's proprietary scrambling procedure in it. The hardware number, which is unique to each single vehicle, found in the "English" software is also exactly identical to that from one of our Swedish cars. In this case the hardware number (23755R099802253) is from 2002, and belongs to the stock software from a 9-5 B205E in Borås, Sweden.
The company in question is a well reputed company, with a number of years' experience from Saab tuning. They also market themselves as a highly skilled company.
We at Maptun think this is very sad.
Best Regards, Maptun Sweden
Että näin
TUNING PIRATES
Että näin
#1730
500whp.net member
500whp.net member
potkuhousu
Paha isku engelsmanni Abbott liikkeelle, OOPS lipsahtiko multa sen firman nimi nyt vahingossa
Jyrki alias potkuhousu
SS-K #1636 STCF #2
SS-K #1636 STCF #2
Tomi Liljemark
- "Turbo"
Firges9000
- "Saabisti"
Tomi Liljemark
- "Turbo"
Mutta ei kai tässä oo kyseessä "saabilta saa kopioida softaa, mutta meiltä ei"?TuuSaR kirjoitti:Kaikki sen joutuu käsittääkseni murtamaan, jonka takia tunafirmoja on todella vähän ja tuotteiden tulo markkinoille kestää kauan.
Hirssi tietysti on täydessä yhteistyössä Saabin kanssa.
Saab 9-5 2.0 Aero BP XWD -11
#2055
#2055
Niin, ja mitähän varten Maptunin pojat itse olivat boxin softaa katselleet??Tomi Liljemark kirjoitti:Mutta ei kai tässä oo kyseessä "saabilta saa kopioida softaa, mutta meiltä ei"?TuuSaR kirjoitti:Kaikki sen joutuu käsittääkseni murtamaan, jonka takia tunafirmoja on todella vähän ja tuotteiden tulo markkinoille kestää kauan.
Ihan turha näytellä pulmusta, teollisuusvakoilu on normaalia toimintaa eri firmojen välillä, myös virifirmojen.
-barum
Kai maptunilla on copyrightit omiiin softiinsa.
Saab 9000 CS 2.3 vm.92
http://www.garaget.org/?car=21212
Jotenkin en itse näe että kyseessä olisi sama asia, siis käyttää saabin softaa runkona ja tehdä siihen modeja tai prujata valmis modattu tuota toiselta virittäjältä. Tietääkseni se ei ole pois saabilta jos viriputkat myy modattuja softia. Toki ehkä nyt on kun on myös tehtaan oma putka, eli hirsch.barum kirjoitti:Niin, ja mitähän varten Maptunin pojat itse olivat boxin softaa katselleet??Tomi Liljemark kirjoitti:Mutta ei kai tässä oo kyseessä "saabilta saa kopioida softaa, mutta meiltä ei"?TuuSaR kirjoitti:Kaikki sen joutuu käsittääkseni murtamaan, jonka takia tunafirmoja on todella vähän ja tuotteiden tulo markkinoille kestää kauan.
Hirssi tietysti on täydessä yhteistyössä Saabin kanssa.![]()
-barum
#1730
500whp.net member
500whp.net member
Tomi Liljemark
- "Turbo"
Kyllä tuo, että kopioi suoraan toisen tekemän softan ja myy edelleen sitä muka omana, on hyvin epäeettistä. Eli siinä kyllä ymmärrän Maptunia täysin.Vigge kirjoitti:Jotenkin en itse näe että kyseessä olisi sama asia, siis käyttää saabin softaa runkona ja tehdä siihen modeja tai prujata valmis modattu tuota toiselta virittäjältä. Tietääkseni se ei ole pois saabilta jos viriputkat myy modattuja softia. Toki ehkä nyt on kun on myös tehtaan oma putka, eli hirsch.
Mutta, jos ottaa pohjaksi softan, niin onko sillä väliä onko se saabin tekemä vai saabin+maptunin? Saabillahan on myös tekijänoikeus omaan softaansa. Eihän Maptunkaan saa myydä saabin softaa (muokattunakaan) ilman saabin lupaa, vaikka se ei olisikaan heiltä pois? Mutta ei tätä tarvitse sen enempää vatvoa, tarkoituksenani oli vain tarjota toinenkin näkökulma asiaan. Luotan paljon enemmän Maptunin softiin, kun heiltä löytyy oikeasti kokemus ja tieto softasta.
#2055
#2055
